dwb
- 1,571
- 1,089
- Sep 9, 2021
Broomfield,
Colorado
What is the minimum thickness of a 1g head to still run an OEM headgasket without piston to valve clearance issues on a stock/OEM build?
I *believe* my head was never milled previously and the machinist had to take 0.008" from the deck. From my research, this is the max amount according to Mitsu. Another 0.001" was taken off the block deck. So 0.009" was milled between the two, which puts me 0.001" over Mitsu spec.
So I measured my head thickness to be sure. Unfortunately my calipers are not the highest quality nor calibrated. It came out to be 5.190" which puts me at 0.010" shorter than a new head. So either the head had been milled previously unbeknownst to me, my calipers are not accurate, or the machinist took off more than 0.008". I'll try to find a calibrated tool to verify. Anyway, if I take this at face value, I'm at 0.011" total material removed between the two deck surfaces or 0.003" over Mitsu spec.
I've read some things about "AREA" spec, which says 0.015 total can be removed without adjustment. I'm within that spec, but what does "AREA" spec mean and is it a reliable source?
I already have a new Mitsu OEM HG and would prefer not to waste it, but I could still go with a thicker HG if needed.
6bolt block/rods/crank, 1g head/cams, 2g pistons.
