schafer240
5+ Year Contributor
- 92
- 46
- May 30, 2021
Kelowna,
BC, Canada
I've done a far amount of research and understand both are china castings and then machined in the states.
The best poster I found on the eagles was Tim at TMZ, pushing them over 800whp and being completely fine, as for the Manleys there was little to no information on them other than supposably they have a better machined final product with no evidence.
Price Difference
Eagles - $425.62 USD
Manley - $518.00 USD
Weight Difference
I already have purchased both sets of rods and and can run either in my 2.4 build. Im going to keep it at around 700whp with an Eagle crank and Wiseco Pistons.
My question is which would you run between the two at this power level and why?
Please keep this informative, not "Manley because its amazing", "Eagle because its rated at 900"
Any good information is much appreciated, thanks guys
Price Difference
Weight Difference
| Eagle Part Number: | HP Rating: | Rod Bolts: | Pin Size: | Pin End Width: | Weight: |
| CRS5900MA3D | 900HP H-Beam | 3/8" ARP 2000 | 0.827" | 1.117" | 575g |
| Manley Part Number | Application | Center to Center | Big End Bore | Big End Width | Pin Diameter | Pin Bore | Grams |
| 14021‑4 | 6-Bolt 4G63 | 5.905" | 1.890" | 1.115" | .827" (21mm Pin) | .8281" | 550 |
| Notes: Recommended bearings to be used: ACL 4B1146/H or Clevite CB-1120AL |
. I personally went with Manley “turbo tuff” I beams for added strength. I know they’re heavier than h beams and are said to be harder on bearings, but which would you rather beat up? A $100 set of bearings or a $700 set of rods? The bearings can be replaced on a refreshed block, those I beams can be re used and won’t fatigue and weaken like aluminum rods. I know aluminum rods have their place in RACE engines, but even the Red Demon replaces them after so many runs due to stretch. Look up the HPAcadamy podcast with Devin Shultz and he explains the finite life of aluminum in high horsepower applications. All I’m getting at is a strong steel rod can be re used for a high power STREET car. I personally would lean towards a proven I beam/X beam for power and longevity
