2G Manifold to turbo gasket
So I just got my gaskets and such today from extremepsi everything looks good except for the manifold to turbo gasket, the port/hole on the gasket is a little bigger than the one on the turbo is that gonna be a problem? Fits perfectly just the hole isn’t right is that normal
I would think as long as the gasket isn't smaller than the MANIFOLD hole then you should be fine. Otherwise, you'd have exhaust running straight into your gasket.
Damn, I didn’t get a turbo to downpipe gasket. Am I screwed?
You mean O2 housing to downpipe gasket? Do you have a pepboys locally located? You can find them at some auto stores they're not too hard to locate. And you should really run one. You don't want an exhaust leak.
That link you provided with that gasket; that should work just fine given that it's the appropriate size.
You can always go all v-band, then you can't forget the gasket haha
What’s vband? This is only a temporary turbo change because my current one has play but I have a back up. I got the gasket I need I’m doing the swap right now.
