turbo to manifold gasket
green97gstspyder
143
Mar 14, 2012
newark, Delaware
I have a turbo to manifold gasket that is all metal and looks like it is more than one piece from the mitsu dealer. My problem is that the hole is way to small for my bep housing. Can i enlarge the hole with a dremel or will it ruin the gasket?
it has a seam around the outside but where the hole is its smooth on both sides and the inner edge is covered so you cant see any layers
Where can I get that one from? I would have thought for the cost of the housing it would have come with it.
stealership, extreme psi, STM, MAP, etc...
Edit: yeah what justin said. the turbo itself... and the housing are WORTH the price alone. although my turbo did come with an oil drain gasket thats better then the one my drain kit came with. thanks justin :) :thumb:
