low throttle problem
toyotwo91
40
Mar 8, 2011
minerva, Ohio
Today I changed my bov cause I thought it was leaking. I went back to my stock one. Now all the sudden my car runs bad. At high boost it runs fine. But when cursing w the the throttle barely cracked it sorta chugs along. Only way to explain it. Maybe alil like a miss.,also its missing at 4500 rpm. I read through the search, and seen the 4500 cut out is from a boost leak. Why is this? I'm currently looking for a leak in the stock pipe but not finding anything
Don't forget to check the brake booster vacuum line. Also you might want to look into rebuilding the throttle body if its leaking.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
