schafer240
- 91
- 44
- May 30, 2021
Kelowna,
BC_Canada
Car ran great previously on stock computer with a Safc with fic 650's, Been having this issue with my car since I got link with SD and pte 1000's
Im mostly looking for common causes that would lead to this, i have searched on here and the ECM Link Forums and havent came up with much results, seems like everyone struggles with high values.
I have to raise my SD starting table values to 65, which is way to high on my 2.4 stroker to get a .27 value. At a table value of 50 I get around .20 airflowperrev and my load factor drops to .10 and drops out of closed loop.
Extensive Build list can be seen here --> https://www.dsmtuners.com/dsm-profil...eclipse.16254/
Compression tested 185psi straight across on cp pistons
Mechanical timing is correct
Ignition timing is correct
Fresh br7es plugs
Boost leak tested to 30psi
Fuel pressure set to 43.5psi
Pte 1000cc injectors
Wally 450
I attached a quick idle log, I know my isc position is high, I have been playing with the throttle screw and it is a pain to dial in as I have a 74mm S90 throttle body and they don't have a bisc screw, I keep getting it close then it wanders.
Ive taken the Evans tuning course and read lots on link so I understand the program and how it all works, other than how to manipulate my airflow per rev without over inflating my reported airflow values in my SD chart.
Thanks in advance, I'm really stumped on this one.
Fresh br7es plugs
Wally 450
