randyknight
- 0
- Jun 10, 2010
pell city,
Alabama
ok i used to beable to post in all sections of this fourm, but im not sure what happend to that... but i found this thread and its kinda like this.. http://www.dsmtuners.com/forums/cylinder-head-short-block/395950-oil-pressure-problem.html
i built a 2.4 stroker have a 4g63 6bolt boared .20mm over 100mm eagle crank, weisco pistons, manley H beam rods ARP main studs.. spec on main and rod bearings was 1 thousands when i built it.. it has about 4000 miles on it and has been running great for two years now... i was driving to a friends house to take off my old turbo and install a new (bigger) one. cruising at about 60 mph i had about 55 psi of oil pressure.. normal for what it has been runing... i noticed it started dropping very slowly.. it dropped to about 40 psi at 60mph... i got to his house and installed the new turbo.. when i started it back up my oil pressure cold at idle was like 12 psi.. alot lower than it had been being.. checked the oil, and it was good.. so i drove it home (about 10 miles) it is now reading about 24 psi at 60 mph.. 60mph being about 2500rpm. i installed a new oil pump and BSE kit when i built the motor. any sugestions before i just pull it down and replace all the bearings, oil pump, and BSE kit????? help me if you can... no weird sounds or anything.. i remember having to port the oil filter housing when i built it because i had like 75 psi of oil pressure at warm idle...
).. i will post updates..
