loud clunking on deccel
mr arizona
30
Mar 9, 2011
prescott valley, Arizona
Ok so when I left off the accelerator I hear a very loud whack whack whack until I hit the pedal then it goes away as I gain speed but at idle I do not hear the noise, also when I push in the clutch I get the noise again I can feel it in the floor board on the driver side. The noise sounds like it is coming from the driver side I am going to check some things tomorrow just wanted some more ideas thank you
So common problem I am guessing best thing to do is just rebuild it I am guessing or just new crank bearings and call it good around how much to fix it
SEARCH FFS
Did you even bother to check your motor mounts?
Why exactly do you think your 420A is 'walking?
It's to dark to check anything right now so I will check tomorrow in the morning so 420a motors don't normally walk ?
+1 on the motor mounts. The rear or front one is likely your culprit
So hopefully motor mounts but could possibly be crank walk talk about from one extreme to another
You know what? Yes, it's crankwalk, you'll have to replace the engine, you can't repair it.
Absit nailed it. It's crankwalk, that bi*** is a walkin on you.
No, seriously though, it's not crankwalk. Crankwalk is way over hyped and it was typically only the 7 bolt 4g63 that had issues with it.
So don't worry, you have a 420a.
Ok for all u ####in smart asses I know not a thing about import but does anyone know 18436572 like the back of my ####in hand I do work on cars and love to but need information that's where u guys come into play but no let's play johnny #### the dog and mess wither the noob I was honestly looking for helpful advice not smart ass comments thanks for the entertainment Asshole
Classy, but you should probably know that your car is more Chrylser than Mitsubishi, and a crank is a crank, regardless of its country of origin.
