Loud clunking and idle problem
x-kiwi-x
80
Apr 9, 2009
Olympia, Washington
Ok guys. Rebuilt my 7bolt about 500miles ago, then blew the head gasket (dont ask me how) but after having the head at the machine shop for a full rebuild, a new gasket and hydrolic timming tensioner later all looked good. Also put a 1g TB on it, and ported the intake, used my same tps and iac from the 2g TB.
After tuning in the tps i started it up and it has been running really ruff, idling high then dying. I played around with the tps and biss screw making sure it was all right, after that it idled high (about 1200) but was ok. I drove it a lil bit maybe 20miles and now it wont even idle and there is a very loud clunking noise comming from the engine from the time i start it up along the whole power cure, getting louder as the rpm goes up. Also have lost power, i can hear the turbo spooling but not getting any power, car just bogs out. Alot of stuff i know.
Help please, car has been off the road to long.
Crank sensor was replaced when engine was rebuilt 500m ago, and correct me if im wrong, if they were bad then the car wouldnt fire up?
Honostly no. I dont have a day off to sunday either so until then i cant do much. Just figure ill pull the valve cover and see if anything looks to funky.
my sisters old saturn had a crank sensor that was bad and it was making a clunking sound and i took it off and replaced it and all was fine. the mounteing tab was broken and it was rattling something feirce.
i just replaced the crank sensor and it was working fine. till i replaced the head. :confused:
So iv had a couple of sugestions, just wondering what eveyone else thought before i go tearing it apart. Been told that the head gasket coulda collapsed the exhaust, which would account for the loss in power, and also a chance that since the cylinders where full of coolant that it would have put alot of stress on the bottom end throwing a rod bearing.
What you guys think.
I havnt done a compression test, but considering that it is a rebuilt block and head i wouldnt expect that it would be a compression problem.
