o0GuitarKid0o
- 1,069
- 164
- Dec 12, 2013
Winnipeg ,MB,
MB_Canada
sorry this is so long, dont be scared ive listed alot of stuff so you guys can help me!
issue:free rev with overdrive on , off no issues
alright ive researched alot even replaced my pulse generators due to them being out of spec .
this fixed some shifting issues but now i lost over drive it just free revs (it shifts into over drive, but just revvs though so not the pump and started happening yesturday)
so im thinking i should swap out the end clutch assembly with a known working one from a awd part out whitch brings me to the question can i use the awd turbo tranny end clutch in my fwd turbo auto tranny? looking in the manual they seem to be the same part then that will give me enough time to rebuild my end clutch with the ipt kit
the tranny was rebuild around 100,000km ago( by previous owner) new 2nd gear band clutch packs , new pump, and a bunch of other things i cant remeber but can get my maintance list and check if need be.
if i put overdrive off it shifts normally
i get trannsmission codes ( i used a mmcd version for transmissions can give the softwear to any one interested) 82, to do with pulse generator b
code 13 tps out of adjustment
sometimes code 84
some things i want to claify is how hard is it to just swap out the whole end clutch ? do i need to drain the fluid ive heard you can drain a quart and have at it?
link from person with simular issue
http://www.dsmtuners.com/threads/weird-od-issue.439059/
and sites i looked at about end clutch
http://www.plymouthlaser.com/ec.htm ----end clutch install
any input appreciated like litterally anything this is putting off my paint job and this is my daily driver ive got other vehicles i could use if need be but i hope i can fix this!!
im running a 91 f4a33 turbo automatic transmission (fwd) and for some reason i have a awd end clutch cover but instead of w4a33 its w4a32?
litterally need to fix this before winter
sometimes code 84
