BLKGSX23
- 91
- 0
- May 1, 2009
Sullivan,
Missouri
Car drives and runs really good..better than it ever has...but when in boost and letting off it blows out quite a bit of white smoke...white smoke usually means coolant right?...I did a compression check and it's 175 across the motor and I have no leaks under the car..coolant and oil is clean as new but I just noticed I am loosing coolant somewhere...just had to add some...could I still be losing coolant on a water jacket on the head gasket but still have good compression?
