kenamond
DSM Wiseman
- 3,225
- 68
- Feb 15, 2006
Los Alamos,
New Mexico
I'm getting ready to replace my stock 2g lifters with revised lifters (TopLine). I've got the lifters and new VC gasket set, I've read the vfaq article a few times, and read all of the threads I found on this forum. But I still have a few questions. I'm one of those guys who has to know how to do something before I do it or I don't do it.
The vfaq article implies that when the cam lobes are up that there'll actually be no compression on the valves/rockers/lifters. Is that true? I know you still have to compress the valves to get the rocker off the lifter, but is there actually no compression on the rocker when the lobe is up?
When prying (either for removal, installation, or seating the rockers on the lifters), should I use blocks of wood to protect the aluminum head from the prybar and screwdriver?
When a rocker comes off, I don't want it flying off somewhere I can't find it (my garage is still recovering from my wife's recent garage sale, so there're plenty of hiding places for a tiny rocker to find). Any recommendations on how to keep the rockers from disappearing (rag over them?)? And should I use a face shield
Everyone says that the motor will tick for a while after putting in the drained lifters. If that's the case, I can't see how priming them with the MPI fuse pulled would do much of anything (turning the motor over for 30 seconds is nothing compared to idling for 5 minutes). Should I bother with priming? If the lifters are coated in oil, I wouldn't be worrying about dry metals touching.
Finally, for those of you who used TopLine revised lifters, are they full of oil in the plastic wrap? I'm not opening them until I'm actually putting them in (decrease chance of dirt). I know to drain them, but I'm wondering if they're just coated and drained already or full of oil.
The 2nd part of the vfaq article talks about rotating the oil passages to be 180* out of alignment, but the 1st part says the lifters rotate normally. So do I rotate or not?
As you can see from my questions, I like to know the details before I start. Maybe a personality flaw, but my projects almost always work out great as a result.
I intend to take plenty of pictures and put a tech article together with a lot more than the vfaq, but that assumes this all goes smoothly.
Sorry for the length. Answering any of those specific questions would be greatly appreciated! Thanks!
?Everyone says that the motor will tick for a while after putting in the drained lifters. If that's the case, I can't see how priming them with the MPI fuse pulled would do much of anything (turning the motor over for 30 seconds is nothing compared to idling for 5 minutes). Should I bother with priming? If the lifters are coated in oil, I wouldn't be worrying about dry metals touching.
