lazyazzdaddy
- 260
- 1
- Oct 31, 2006
Hagaman,
New York
ok well let me start off by saying this all happened about a month ago. i was out driving my car and yes i was driving it hard. not beating the piss out of it but i was driving it hard and like so for about 3 miles. after a sharp corner i go to get back on it and poof i hear a popping noise and suddenly the engine starts to die out much like blowing off a intercooler pipe. well, i get out of the car and first thing i check is the oil level and coolant res. the oil is almost completely missing from the dipstick and the coolant overflow is completely full. intercooler pipes were all tight. i also checked the timing belt thinking maybe i broke a belt or skipped some teeth or what not. every thing looked fine. now, before i had gone on the drive i checked all fluids and everything was perfect.
after being towed home i desided to check my oil again and this time it reads full "right where it should be"
so i started to tear down the engine got the valve cover off and noticed two lifters had broken off at the "ball" and were laying inside the valve cover area . got the head off to find two broken valves & my #1 piston with a huge hole in the middle of it which i beleave was caused by the valves in the cylinder.
i was logging the whole run when this happened so i went thru the log to see what was going on when it blew and nothing. the log looked great , no knock what so ever.
So that brings me to my question. has anyone ever experienced this before? i am leaning towards either a faulty lifter or maybe i had a clogged oil passage or something. I had to put a rebuild off to source out a new head and block. with the way my luck works my #1 cylinder which had all the pieces of the valves in it was fine. but my #4 cylinder which only had a small piece of metal in it was toast. i was already .20 so i figured i would rather go fresh 6 bolt instead of .40 . So i now have a new block and head and am about to start the build. i'm not a newbie to these motors but i know there are some guys "and girls" here that could run circles around me and i'm hoping i can at least get a reasonable idea of what happened. so i can make sure this does not happen again. at the time i was pushing around 500hp at 35psi on e-85. i was pretty much maxing out my hx35. with my new build i plan to push it up a bit to 650-700 whp range. using a gt 3582r with a billet upgrade. so obviously i want to make sure i have all my ducks in order. thanks in advance for your help
ill post a few pictures and if anyone want's to see more please let me know.
so i started to tear down the engine got the valve cover off and noticed two lifters had broken off at the "ball" and were laying inside the valve cover area . got the head off to find two broken valves & my #1 piston with a huge hole in the middle of it which i beleave was caused by the valves in the cylinder. i was logging the whole run when this happened so i went thru the log to see what was going on when it blew and nothing. the log looked great , no knock what so ever.
