Leaking fluids after turbo swap
Dsmj89
3,249
14
Nov 11, 2008
Miami, Florida
I searched and couldn't find the answer to my question. I recently did a turbo swap and re-checked that everything was hooked up correctly. Car idles and runs fine.
Now i have 2 problems, my car is leaking coolant around and between the upper radiator hose and one of the rubber hoses from which the turbo feeds coolant off of, and i have an oil leak, i would say huge but not visible.
Have any of you guys run into a problem like this before leaking fluids after an install ? I know these are old hoses that need to be replaced due to their age and wear and tear. I didn't expect that after taking off a hose and putting it back on it would run a chance of leaking ?
Also i put in 4 quarts of mobil 1 fully synthetic oil and the next morning it was down to the 1st line on the oil dipstick, it hasa minor leak where the oil return bolts to the oil pan, but it's a leak that leaks only drops, could it be possible for that little area to leak that much ?
Thanks in advance for any help. I am looking to fix this problem next week when i have a free day off from work.
when you take off the oil inlet pipe from the head, there are two little orage rubber rings, if you loose one of these, or even just drop one they are about impossible to find cause they are so small... double check all your seals and stuff
Your rubber hoses that are leaking coolant are probably old and bad/cracked which is totally normal. You took them apart and now they are leaking so just replace them. If coolant is leaking around the upper radiator hose check to make sure the clamp is tight and if it is and it's still leaking replace the hose. If your oil return line is leaking replace it. If it's not the line and just around the gasket, replace the gasket. You need to locate where the leak is coming from and fix it. It shouldn't be anything too hard. JUST DO IT. :D
  • Wanted ISO Leveling valve assembly, Mitsu part MR135668
    Just bought a 98 Eclipse, while removing the fuel tank I accendently broke the Leveling valve...
    • briang26
  • Wanted 2g Trunk/fuel door release lever
    Looking for a 2g black fuel door/trunk release lever in good shape
    • jesse12345
  • For sale 2g parts
    Evo 3 Big 16g, xs power t4 manifold, various other parts
    • heresjimmy42
  • For sale 1G ETS street core
    1G ETS street core- USED
    • ist dwa
  • For sale 4G63 3 inch Magnaflow SS high flow cat. CA approved.
