lc-2 setup help
bowens1414
123
Oct 30, 2012
Bradenton, Florida
alright alright alright, my wideband just came in today and lucky me i ordered and lc-1 and an lc-2 showed up at my door, i aint complaining. any who when i go to install the o2 sensor into my test pipe will i need to get stm's bung that distances the 02 sensor from exhaust flow. or is that the beauty of calibration? can i just put the 02 right in the hole that is given on the test pipe?
You should not use the anti-fouler for a lambda sensor. Only use those if you can't trick your ecu when using a stock senor without a cat.
Where did you order it from? I'm holding off on my purchase because I want an LC-2 over an LC-1
I know this is Ebay but it works great and the price is certainly right:
Innovate LC1 Wideband O2 DB 52mm Kit Red Gauge Display LC 1 Tuner Combo | eBay
$157.44 to my door and its in the car and works wonderful. So if you want that LC-2, you can get it now at the LC-1 price. I like to do my business with the vendors on here and they get 90% of it but this was a real good deal. MTC.
Also, my wideband sensor is in my factory O2 location, up front. Using simulated narrowband in Link.
