greekgodchaos
- 565
- 213
- Jul 4, 2007
Vancouver,
Washington
This just popped up today, my 1ga Eclipse has been sitting for a bit (chilly weather without a battery tender, was sitting at around 10v, -Optima Red Top-, is now charged up with a new 4amp gel charger/tender), when I turn the key to the ON position, the green light flashes for about 10 seconds then turns steady green: so normal there (the serial cable is plugged into the Serial to USB cable/computer, which WAS working prior to this issue). Then when I click the app to start it, the light goes out and says it can't connect. I can recreate this every time and I just can't figure out why. The fuses are intact, the ground is secure to the battery negative, all the connections are good and tight, so I'm just stumped.
