97egl
- 878
- 566
- Feb 6, 2014
Brownsburg,
Indiana
I bought an aftermarket knock sensor which I know is a big no no but I figured it had to be better than mine which was so bad it set a code.....big surprise the connector has slightly different tabs so it won't plug in.
I'm trying to figure out which wire needs to go to which on the knock sensor. Engine harness has a black wire and a black w/ white stripe. The knock sensor has one wire that has continuity to ground and the other wire has high resistance to ground. I thought I had figured out which wire was the "grounded" one based of the schematic in the FSM but the drawing is wiered and I don't want to fry something.
