knock sensor problems
How many pins does your MAF connector have? Do you have a BCS? Or an injector resistor pack?
What about at the ECU -- do you have pins 105 (for BCS, orange wire), pin 14 (for MAF reset, green with white stripe wire), or pin 9 (for knock sensor, white wire)?
Does any of the wiring around said plugs look as if it'd been "repaired" at any point in time?
It is possible you have a non-turbo harness in the car. Looking for these items will help you determine if that is the case.
My maf is a stock 1g and it plugs right into the harness and the maf is from turbo car. And the bcs LOL most dont even know what one looks like and no i dont have one. Injector resistor pack yes i have that. And as for ecu pins i have not checked for that
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
