knock sensor problems
Cantu23
Dec 15, 2009
Dixon, Illinois
My car is throwing code 31. I replaced the knock sensor and still get it after a couple minutes of idling. I tested the white wire for resistance resistance is pretty high. I can't even get a reading unless I'm on 200k ohms or higher. Where does the black wire with the white tracer go to? Using my logger I get either 0 or 9 counts of knock. Sometimes it will throw in a random 3 counts but that's it. Any ideas?
Well I checked resistance from the ecu to the clip and it was pretty high. Do you think its just the white wire having high resistance that is the problem? Where does the black wire with the white tracer run to anyone know? I can't even get a resistance reading without it on at least 200k.
Alright I'll give that a try. Can I ground the wire in the engine bay incase the ground is bad?
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
