Kiggly 6bolt crank trigger
Yamahaulin
695
12
Jan 30, 2010
Bowling Green, Kentucky
I'm installing a new harness in my car, it's a 95 with a 6bolt swap. I have been using a green top cas and i want to switch to a black top. Do you guys think it would be beneficial to buy the kiggly crank trigger setup when i redo the wiring harness? I have dsmlink so the cel is not an issue just wondering if it would be a better setup than i'm currently running.
With the Kiggly crank sensor you must utilize the original cam sensor from your car (being a '95, the one behind the intake cam sprocket): http://www.dsmtuners.com/forums/newbie-forum/396152-kiggly-6-bolt-crank-trigger-sensor.html.
Assuming you are no longer using your vehicle's original head, it would be much easier to utilize the 1G CAS and bypass the CEL with DSMLink as you already have it set up and it costs you nothing aside from the "new" CAS you mentioned obtaining. There really isn't any performance benefits running it one way or the other, as far as I know.
