boosted92laser
- 107
- 1
- Sep 13, 2006
kankakee,
Illinois
Now that I have my oil pressure problem under control, I did a boost leak test. I filled it with 20psi and heard a hissing and kind of a bubbling sound. I figured out where my only two leaks are. One is the turbo oil return line, it has a small crack in the flex section, which I am going to replace before I drive the car anymore. The other spot it is leaking from is the dipstick tube. If i pull the dipstick out, all (but about 5psi) of the pressure will come shooting out. I did some searching, but didn't find the information I was looking for. Is this normal? If not, what can I do to fix it?
Thanks
Thanks
