issue with blinkers :(
visching101
Mar 3, 2009
LI, New York
Ok i did a search and see a lot of people having issues where none of the blinkers work (but hazards do) and so on.
Unfortunately for me... That sadly is not the case for me, or i would have lots of suggested fixes to go off of LOL.
Ok so I have a 95 gs-t and my issue is that the front turn signals do not work. The light will come on with the headlights, but the signal itself will not flash. The rear however work fine. Even when i put my hazards on, the rear work but the front do not.
I have checked the fuses, i changed the bulb just in case they both had gone bad, and still have had no luck. Does anyone know off hand where they ground? Maybe its a bad ground? I Dont know, but any help would be appreciated.
Have you taken a test light to see if the plugs are getting power (probably not but a good place to start)? I would start there and trace the wire back to see if there is a short somewhere.
check and replace the relay in the center console, behind the center vents. to make sure the flashers relay is good I think the circuit grounds out somewhere behind the radio
