blinkers dont work.
marsh63
517
Oct 15, 2007
richland, Washington
90 eagle talon tsi. ok to start off someone stole the dash out of this car and then somone else replaced it. but none of my blinkers work and the hazards dont either. the head lights and tail lights work but no blinkers. and will someone tell me how to get my lights to come down from in side the car. is their a button somewhere
any help would be great.
Usually, the lights will come down when you flip the headlights off. Otherwise, there is a button to the left of the steering wheel (believe there's 3 buttons vertically). Without running out to my car (3am) the easy answer is it's one of those buttons :) I've never used this button which is why I'm not 100% positive but one will surely work. If not, post it up and there's plenty of people who will answer why they won't work.
CLIFF NOTE-3 buttons to the left of steering wheel. One will work.:rocks:
EDIT- top button, left of wheel (can't be seen in this photo but it's above the fog light and dash "bright-o-meter)
http://www.dsmtuners.com/gallery/showimage.php?i=80126&c=504
1st step for blinkers/hazards is check the fuse/s (under the dash to the left)
yeah it only has one button but like 3 wire harnesses that go the. 2 i dont have buttons for. um dose anyone have a fuse layout. idk what fuses do what.
Honestly, I'll run outside and take a pic of the layout for you. However, there SHOULD be a black cover that explains where everything is. I'll upload a pic in a few. Stay posted.
Ok, the "middle section" of the fuses is what your trying to look at. (Cell phone pic didn't come out good enough.)
Now, seeing as how I'm not 100% positive as to how this fuse cover goes on, try to follow me here. When looking under the dash, to the left, you'll see the fusebox. To find out what is the actual "middle section" that I'm talking about, go by my crappy diagram. The key is to look at the amp ratings on the fuses themselves.
1st row Middle 3rd Row
15amp 10amp 10amp
10amp 10amp 10 amp
10amp 10amp 15 amp
blank spot 15 amp 30 amp
10amp blank spot Blank spot
10amp 10amp
15 amp Blank
The underlined 10 amp in the middle section is the turn signal fuse. If you need further explanation, post it up.
alright well its fine and its not blown. i think im missing a switch but im not sure. i still cant get the headlights to come down either on their own
