Is this pattern correct? (coil & Plugs)
Drift_SM
772
5
Jul 28, 2005
Titusville, Florida
I know the pattern is.....4-1-2-3.....
but is that staring from the coils or cylinders... i drew a pic
is this hook up is correct? (colors are to keep wires unmixed)
pattern
Only thing I can guess is because he is running a 95 eprom ecu. I dont have first hand experience with it but I was told that you have to switch your plug wires around on a 97-99 when running the 95 eprom. Your best bet is to pm andy and ask him.
Keith,
That's EXACTLY correct. Since I use an EPROM ECU, the CAS signal is inverted to interface a 98 CAS with the 95 EPROM. Nevertheless, I still have to switch the middle and end plug wires around to get it to fire correctly.
Thanks for the PM and I hope that helps,
Andy
