Is a n/t throttle body a direct bolt on for a 90 1g
matt jones
160
Jan 16, 2010
HuntingtonBeach, California
Hey how's it going....I have done some research and can't find any answer....I wanted to know if the non turbo throttle body is a direct bolt on with a 90 1g....I compared the two and it bolts on but the black sensors on the tb are different from one another....my tb has two wires coming from the black sensor connecting to the throttle body itself and the non turbo one has a connector plug on it....if u can help me out it would be much appreciate....thank you
A 1g NT will bolt right up yes. You being a 90 have an oddball single year production throttle body. You just need to get the wiring hooked up and it'll be fine. You will want to get the NT throttle body rebuilt with new seals so it can 1. hold the boost pressure and 2. is no longer a boost leak.
Thanks for the response...now is the wiring for the tps
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
  • For sale 4G63 Griffin intercooler cores
    Griffin intercooler cores. Top to bottom flow. High cfm and heat transfer. 24x8x2.75 and...
