90 throttle body on a 91
defiancy
Feb 6, 2006
San Diego, California
I know the popular mod is to put a 91-94 on a 90, but I have a bad 91 throttle body and a cherry new 90 throttle body. I know you can cut the wiring for the 90 TPS and wire it into the 91 TPS, is the inverse true? Could I cut the wiring for my 91 TPS and wire in the 90?
And if possible, is there anything else stopping me from making the swap?
You're in luck. It's a straight bolt on besides the wire TPS wire modification. The 91+ TPS doesn't fit the 90 TB unfortunately.
Instead of splicing, you could cut your 91 TPS connector off, snatch a 1G/2G radiator fan connector (opposite engine harness), and solder onto your 91 engine side harness. This connector matches the 90 TPS connector.
Bam, now removable.
Wlemcoe to teh stie
Bam, now removable.
Wlemcoe to teh stie
Thanks man, that's a great idea. Even if I don't do that originally, I'll definitely pick up a connector once I get a chance. Guess I'll give this TB a shot then.
Thanks for the welcome, though I've been on this site since 2006, I just don't post a lot obviously!
I appreciate the response.
