Internal Wastegate help.
4gst
121
Apr 19, 2010
Los Angeles, California
I wanted to see if anyone here could help me with this internal wastegate. I bought it used but during the shipping process the nipple where the vacuum source goes hooked up to broke off. I don't know what to do I don't wanna buy another one cause this one works fine except for that nipple. What would be the best thing to do should I try to drill the jole a little bigger and try to screw a nipple in there. Or try to weld a nipple.
Let me know what you guys think I should do.
Thanks.
If you drill it, be sure you dont hit the diaphragm inside of it. That would be my first choice over JB weld.
i had one break off, i drilled the hole on the waste gate so that the nipple would fit inside snugly, then i brazed it back on.
Alright thanks for all the replies guys. I decided to go with jbweld and a nipple I found laying around. I just finished putting the jb weld so ill see how it dries up.
This is just a temporary fix to get my car runiing till I have enough money to go external.
Thanks again.
Sent from my Ally using Tapatalk
