Interesting observation: Intake Temp
NineThrityONE
57
Jan 6, 2005
Denver, Colorado
I'm just getting my project running and I have a stand alone temp sensor just in front of the TB. Now in my previous set up there was no MAF. My intake temps were, at idle/start up just above ambient (80F*) and normally didn't get too much higher except for heat soak. But after installing the 1g ECU with 2G MAF, My intake temps were showing near 120 just after start (haven't driven the car yet) and I started to wonder if the temp sensor was bad, but after shutting the car off, the temp would start dropping immediately.
Is it the MAF that's heating the air that much?
Is this still the old Porsche you swapped the DSM ECU into?
Are we talking about the exact same sensor in the same location by the TB?
How were you measuring the temp both times?
There isn't anything in the 2G MAF that normally would heat up. The airflow measurement is done by ultrasonic counting of the vortices generated in the airflow not by measuring the cooling effect on a heated wire like a GM MAF. The two other sensors in the MAF are IAT and absolute barometric pressure and neither should be heating the air.
  • Wanted 4G63 800cc injectors
    Im looking for a set of injectors that are at least 800cc. Thanks!
    • DSM_Thorpe
  • For sale 2g 2g rear brace arms
    2g rear subframe brace arms. Missing one of the bushing spacers. No rust. Had someone looking...
  • For sale 1g 1GB Eclipse Tail Lights
    1GB Eclipse Tail Lights $80 + shipping and paypal fees* not flawless but in very good shape...
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
