injbatteryadj or something else
jpmxrider489
2,415
152
Apr 4, 2010
pittsburgh, Pennsylvania
I have this problem stalling when coming to a stop. It did this when of maf. Since I am venting my Tial bov, I thought it was because of venting. So I switched to SD. The problem is still there and is no different from when I was of maf. I will post some logs of SD. Basically I got dialed in at idle on SD and figured everything is fine. I noticed that after I blip the gas or anything the battery volts rise and get steady. I looked on the wiki about the injbatteryadj and it talks about using things like the windows. In my case it seems as if I have to blip the gas to jump start everything. Also after revving or driving the isc wont go back down and my fuel trims are way off but there are fine at idle once warmed up.
My log that is idle sd restart final is when I dialed in everything after starting the car and letting it get to operating temp. My coolant temp sensor is working it is just reading wrong. I am using the coolant offset.
1. RPM/TPS Tab: bump your coasting FC offset to 130.
2. VE Table: 0 rpm column, from 0.0 down to 9.2, make that 55 into a 65.
let me know how that works.
