- Thread starter
- #26
midfb6
- 44
- 6
- Jun 25, 2024
COHUTTA,
Georgia
got everything but this figured out , do i wire the injectors to firing , posted a picture with the orders if u could just tell me if i should do it the top way 1342 or 1234You need it configured like this. However you do that is up to you. The stock PCM, as far as I can remember, should still supply 12V to the injectors as long as it's seeing a crank signal. It should also still activate the ASD and fuel pump relays. You can eventually have MS control those too, but you don't need to change anything there at first.
https://www.symtechlabs.com/docs/ms_wiring_guide-420A-2_0.png
