adammethner05
- 214
- 0
- Aug 31, 2006
Fremont,
Ohio
I'm currently removing the transmission in my 1997 Eclipse RS so I can replace the clutch, and I'm to the point where I have to remove the wheel hub nut to remove drive axle from the car. The problem is, the darn thing just won't come loose
. I've sprayed tons of PB blaster on it to try to eat through the rust and whatnot, and the other day I managed to crack the head of my Craftsman breaker bar almost in half trying to loosen it (using a piece of pipe for leverage of course), not to mention slightly bending the 1" thick crowbar I was using to keep my wheel from turning. I've read the guides on 2gnt.com and I've searched on here and I can't find anybody else who has had that much trouble. Is there any possible way at all that it could be reverse threaded? I've never seen any information anywhere suggesting this, but everywhere I look also says it's a 32mm and mine is only a 30mm. Or should I just bust out the torch and heat that mother up and see if it'll turn that way? Any help would be greatly appreciated, I miss driving my baby.
