2G Hx40 oil feed fitting
Koda
5+ Year Contributor
85
11
Jun 2, 2019
Butler, Pennsylvania
So I have a -4an oil feed line , I just need a link to the right fitting to go from a -4an into the holset feed, I have one currently and it’s the right size just wrong thread pitch and I cant find the thread pitch anywhere, even on holset’s website.
The silver threads on the left are the right size , the bronze one on the right has the right -4an fitting and the same outer diameter on it but just wrong thread pitch
Its a super nice set up for Holsets. Anytime @Koda :thumb:
12mm x 1.5 4AN "flanged" adapter is what you need. Use an o-ring to seal at the top of the threads just as Holset intended and it'll never leak. Restrict to around .100" (3AN I.D.) and run a drain the size of a fire hose and it will never let you down.
