HX40 BEP housing
95eclipseSlow
131
Dec 10, 2007
Taylor, Michigan
Im looking into getting a hx40. I have looked on ebay and all of the hx40 turbos ive seen on there looked fake.Are there any real ones on ebay? Where can i find a genuine hx40 that is in good condition? SBR supposedly has a the BEP mitsu flanged exhaust housing for the hx40. I looked on their site and could not find it. Where can i get a BEP exhaust housing for the hx40? Im not looking to spend a fortune on this.
call SBR about the BEP housings and i thought i saw Extremepsi had them but i might be dreaming LOL
I would look on the cummins forums.. I would also call some of the deisel shops around michigan and see if they have any... They are cheap to rebuild also like 200 bucks..
The HX40 is comparable to a GT35R, which is a huge step up from your current setup. Are you prepared to make that leap?
They're on there occasionally. You just have to know what to search for and what you're actually going to be buying so you don't get ripped off. The general public knows nothing about turbochargers, so they may mislead you unintentionally.
It's not on their site.
How about Bullseye direct?
You may not spend a fortune, but you're not going to get off cheap, either.
i looked on bullseye too and didnt see it on there site. is it a call only kind of thing? im going to move into e85 and doesnt the hx40 spool faster than the gt35r but make just as much power?
You can get a BEP housing from Tim's Turbos - Turbo Rebuilding. He has the mitsu flanged ones in stock and can have e t3/vband dropshipped. You can get a hx40 if you search for guy named saulg one ebay. If you find one of his turbo ads you can call the number he has listed and ask for a hx40. Hes got alot of them, even some volvo billet wheeled hx40's.
Yes call them up or just email. I got a prompt reply from just an email from BEP.
Its not proven the hx40 has faster spool but it seems to from data logs. I have yet to see someone with the same setup test the two back to back on a dyno so no proof. The new HTA tech. is doing really well. I know some one with a 35r hta and it does awesome on his 2.0L.
:) Jay, Badman21 did a DIRECT swap from the gt3076r to the hx40 and the spool was the same. And of course the gt30 turbine spools alot faster than the gt35 turbine. So it would be safe to say that it's been proven by at least one setup with a direct comparison. I'm sure if badman put a gt35r on instead of an hx40 the spool would have been later than the gt3076r. Or we wouldn't see garret providing the gt30 for sale because it would flow less and spool the same as a gt35.
so i should be able to get the turbo and the bep housing for around $450 combined? 220 for the housing and 230 for the turbo? is the evo3 manifold and evo3 o2 housing ok? how can i run an external wg without getting a new exhasut mani? can you mod the evo3 mani?
What are your plans? You definitely need a more mods. Just because you're getting this turbo is not all you have to do. With what you have in your profile I'd say that a HX35 is more reasonable for choice, but that's my 2 cents.
I remember this now, its what made me want to get one in the first place. Where all conditions the same. Same temp, same dyno or street, same tune, boost levels, starting rpms, gear??
Gear and rpms makes a huge difference when boost hits and how fast. Its what makes comparing so hard. If I start at a 200rpm difference in two logs I will see the difference in the spool.
turbodaddy.net sells the housings also along with rebuilt and non rebuilt turbo's, give brant a call or an email, good guy to deal with and quick shipping.
According to badman21, it was a direct swap. Same shop, gear, starting rpms, tuner. Conditions were the same, except a little warmer in the shop for the hx40, from what I recall. The dynograph of the 650 whp hx40 pull in the holset results thread is right over the 550whp gt3076r pull. . .
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
