Spoolin4Ever
- 1,142
- 15
- Apr 24, 2005
Moses Lake,
Washington
TIming tensioner was not tight enough, and timing belt slipped a tooth or 2.
I want to reset the timing.
My question is how do I know when I have it in the right position before resetting the timing belt? So right now when I rotate the engine by hand, and the cams are lined up, the bottom timing mark always ends up on the last mark on the timing marks down below (this is with the timing belt lower cover still on). I turned the engine six times and it always is like that when the cams are lined up.
So since it's timed wrong, how do I know how much to turn it so that I can then reset it?
Should I turn it so the cams line up, and just retime? What about the piston positions? Which is the bigger priority?
Also I may need to pull the head, I have zero compression in number 2 cylinder, i was hoping if I reset the timing it might be back to normal. If not then I pull the head.
