Spoolin4Ever
- 1,142
- 15
- Apr 24, 2005
Moses Lake,
Washington
I bought the leakdwon test from harbor freight. How do I know when it's at TDC, and on compression stroke?
You can also simply remove the upper timing belt cover and turn the crank until the dowels on the cam gears are both pointing up and the white mark on the gear teeth line up.
So no that wouldn't be the solution! Thanks for chiming in though...I appreciate it anyhow.
