How to remove door switch panel
juntjoo
780
Sep 12, 2011
fort myers, Florida
Apparently the previous owner broke these little fastening plugs all along this panel probably trying to remove it but there are two left, the second pic shows one, that dont want to budge. How am i supposed to get this off?
Phillips head scew driver to remove the screws holding the door pannel on and the dcrew behing the door handle also a phillips screw then pop the clips loose by pulling the bottom half of the pannel off first (i found that to be the best method. then simply remove the 2 or 3 screws holding it to the pannel. all done.
Okay, so they have to be separated by screws from the inside of the door panel? What a screwy design. No wonder the guy b4 me broke all those little plugs
Damn near any vehicle ever made will require you to pull the door panel to get to the switches. IT is just how it is. That plastic piece is actually supposed to be attached by plastic studs that are melted to a plastic washer on the back. IT is pretty common over time for them to break and that piece to be loose from the panel. In the time it took you to write and reply to this thread you could already have the door panel off. IT takes literally 5 minutes to remove.
okay okay, alright alright... it still sucks though. my Honda's is much easier to access. thanks tho for the tip. I shall get to it asap
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
