How to mount a AEM Uego Wideband.
Chris_Sag
102
Sep 8, 2010
Bergen, Florida
Just got my AEM UEGO wideband but no instructions of how to mount it.. Do some one have vfaq or something of how i shoul mount it? The wideband is gonna replace the lamda on the downpipe? coreckt? And is it a site where i can learn about afr numbers? This is a new world to me...
Thank you so mutch! But do i have to make a new hole in my exhaust for it or could i just replace one of my to org lamdas? And is it a site where i could learn about AFR numbers and readings?
Use the search function and google and you will find more than enough info on AFR's (or lambda). Most people don't refer to your o2 sensor as lambda sensors, so you may get more helpful insite using AFR's and o2 sensors.
You will need to weld a new bung on the exhaust to use your wideband sensor.
Okey, that we fix;) What should me target AFR reading be when i floor the pedal? The instrument turns red when its to lean and green if its ok?
