bastarddsm
- 5,776
- 1,710
- Aug 26, 2003
Mendota,
Illinois
Over the years I've done a lot of testing with these cars. I've probably spent more money on testing clutches than an average build costs. - Not bragging, just saying I've tried a lot of stuff. One thing that sticks out, is virtually all performance clutches require more throw out bearing travel than stock to fully release the clutch. If you have a heavy pressure plate that touts a light pedal, than it's going to be bad.
Where we end up is something like the classic ACT2600 is right on the borderline of working with the stock clutch release system. That's why if anything at all gets worn it won't release, and sometimes even the smallest improvement can fix the issue. The solution is somewhat simple, move the TOB further. That's not hard to do, put a smaller slave cylinder. One from a n/a 3000GT works will improve release, but it's gonna give you a heavy pedal. If you want to fix it for real you need to work through the whole system. I end up reworking the pedals to have a longer pedal throw, and then use a wilwood master cylinder with an adapter kit to utilize that increased pedal throw. This gives you more release movement, but not an increase in pedal pressure.
I've said it many times, my favorite clutch in my car has been a 2900 with a solid hub street disc and my pedal mods. It's just awesome. Shifts killer, drives nice, doesn't tear up parts, disc doesn't chunk out, pedal pressure is low and it's cheap. Anyway I thought I'd share a couple pictures of my pedal mods and the master cylinder setup. You can see in the pictures of the pedals I mod the upper stop so the pedal can come up further and then clearance the other end some. The pedals remain useable with an oe master cylinder as well.
