how to change oil squirters?
Well the oil pan has to come down thats it. I forget the size socket I used. Its real simple. just one bolt holds them to the block.
2g squirters are a little different than 1g. From how I remember the 2gs you will need to pull the pistons and pull them out / tap the new ones in from the top.
Yeah you can do it from the bottom w/o the pan its just like unscrewing a bolt. I advice to clean the new squirters to ensure of a steady flow.
greathuskie said:
ok well is it possible to do it while the motor is in the car, and ill be damned if im taking my pistons out
i have a 6 bolt not a 7 bolt
sorry didn't realize you did a swap. On a 6 bolt just drop the pan and stick a socket in there and loosen the bolt. Be sure to clean the squirters out. I've heard of letting them soak in trans fluid overnight to get all the little deposits out. Good luck.
