0r1landoDSM
- 213
- 0
- Nov 10, 2010
Long Island,
New York
im undecided if i should turbo it depending on how much it is. or just get a 4g63T.. i've been told MegaSquirt was a good ECU for 420a turbo. what will mega squirt enhance?
A turbo kit can be pieced together for under 1k. Megasquirt is a standalone ecu offering full tuneability. You don't need MSnS but don't expect higher than 8lbs without it, or something else.
If you're thinking about getting a car with a 4G63T anyway, I would recommend you just do that. If you want potential for more power later down the road, it will be much cheaper and easier. If you run 8lbs on a 420a, you'll be lucky to come close to the stock performance of a 4G63T car.
im not sure what i want to do, but most 4g63's out there are beaten to shit. and the 420a is a fun car but wish it had a lil bit more power
If i was you i would give the 420a a chance. It has been proven over and over they can make as much power as a 4g63. You can build a kit for around 700 ish. Seach for stage 2 turbo kit on here and you will find a very well writen form on the parts
You can make 8 psi on all stock motor parts and ive seen up to 26 psi on a fully built block and built head.
Show me a 1000+ hp 420a. You sir, are wrong.
OP: Take your time and get a stock NA 420a and turbo it. In my honest and professional opinion, they are a much easier engine to learn and work on. When it comes to streeting a 420a in comparison to the 4g63, the average DSM'er isn't working with 700+ HP. They are working with anywhere from 250-500HP. These numbers can be achieved on either engine with roughly the same amount of money. It can also be a little less troublesome to build the 420a as there is a limited amount of aftermarket support and there aren't near as many decisions to make pertaining to which brand is better or which brand could possibly perform better than the next. However, the quality products that are offered, are proven and work well.
Oh and get MS. It's the cheapest most effective way to go over 8lbs of boost, reliably.
1000+HP 420a....I'm still working with a local shop for a filled block and welded head running methanol... call me Adam Rau.
I am getting mine together as we speak. One last part I need is the turbo.
Cast t3 manny $90
Blitz inttercooler $90
Wally 255 $90
1g bov $20
Snynapse missing link(requires mods to work) $50
Russel 4an line (went nice on this one) $70
3in intercooler piping $100
Vortech 12:1 fmy $60
Guages and a pillar mount $120
Exhaust flange for downpipe $13
Left to buy turbo $200
