420A How much does full 420a turbo kits go for?
No need for a walbro 255 here, cause the 190 can hold more than 300hp. You could also use a GST or a 3000GT fuel pump for less than 50 bucks.
Not if you are running stock injectors. The stocker can not hit high enough pressure. So unless you are replacing your injectors and buying something to tune with you need a wally 255. Besides its anice piece of insurance since the stocker is getting old and probably can't flow as much as it could.
You can get a used one for cheaper but its just that, used. On something as critical as a fuel pump why risk your engine? For 40 bucks more you get piece of mind. Who knows what condition that used one is in.
Cheap
Fast
Reliable
Pick two...
Cheap
Fast
Reliable
Pick two...
There are a couple things with the 420a that are popular for a reason... the 255 is one of those things...
PS I highlighted the correct answers, your welcome.
Do t25s have the same flanvge as the t3? I'm gonna go with a godspeed turbo. From what I have found their turbos are decent as long as you don't boost too high.
if you have the common "log" manifold, it should bolt up no problem. the t25 is pretty small but its good and lasts a long time. its found in the GST/GSX but it can fit our cars with a little work.
to be totally sure, just take a quick picture of the flange and compare it to the turbo.
Sorry to butt in but is this turbo kit a decent buy saw this post was on a bulid and im trying to do one myself
95- 99 eclipse 420a talon t3 turbo charger kit FREESHIP - eBay (item 320650990264 end time Feb-07-11 15:40:19 PST)
- Honestly thats an okay kit, you would still need to invest money in an intercooler,piping,bov, and an fmu or a sfmu if you could get your hands on one!
If you put this kit on and not beat on it, i believe it should last you some time!
- IMO, i would get used name brand items tho, better than ebay! just my 2cents.
