rdeis
- 98
- 39
- Feb 28, 2013
Falcon,
Colorado
Hey all! I'm chasing a weird low RPM idle stability problem that has a *huge* hot start component. It settles down after its run for a bit.
The fact that I can stall at a light in hot weather and have trouble getting restarted until the fuel pump has been running a while suggests to me that I've got a problem maintaining fuel pressure. I've gone so far as to install a button in my cabin to run the pump via the check connector. That helps, but it's not instantaneous.
I'm showing the proper ~37 plus boost pressure on my FP gauge when its running. I drove the car this morning and now 8 hours later the fuel pressure shows zero.
Am I right to suspect the Fuel Pressure Regulator or the pump check valve are letting it leak down too fast when the pump is off?
