Hotrodders(dsms)vs Ricers(honda)
Status
Not open for further replies.
4geze63
891
3
Nov 18, 2003
edmonton,
HOTRODDERS: keeping a low profile and letting the et's tell the story
RICERS: Hoping the outrageous body kit will distract anyone from discussing
et's
HOTRODDERS: Sideways into third gear
RICERS: Sideways to avoid high-centering on a speed bump
HOTRODDERS: Tall spindle conversion for better camber gain and tire wear
RICERS: Lowering 3 inches and ruining tires with 4-degrees of negative camber
HOTRODDERS: 600 HP on 92-octane pump gas
RICERS: 300 HP on $3-a-gallon 100-octane race gas
HOTRODDERS: Swapping stock 14 inch wheels for 17s to clear trick brakes and
suspension
RICERS: Swapping stock 14 inch wheels for 20's despite stock brakes and
suspension
HOTRODDERS: Boost gauge on a blown car, nitrous gauge on a squeezed car
RICERS: Both gauges on a normally aspirated car
HOTRODDERS: 500 lb-ft of torque at 3500 rpm
RICERS: 50 lb-ft of torque at 35,000 rpm
HOTRODDERS: Headers and 3-inch exhaust
RICERS: Stock pea-shooter exhaust pipe with 5-inch tip
HOTRODDERS: 600 HP makes for an earth-shaking street car
RICERS: 600 watts per channel makes for an ear-shattering street car
HOTRODDERS: Buying an aftermarket shifter for shorter throws
RICERS: Buying an aftermarket shifter for the lighted knob
HOTRODDERS: Composite parts for light weight and aerodynamics
RICERS: Composite-veneer dash trim and gauges
HOTRODDERS: Upgrading to a 9-inch cuz you keep breaking stock rears
RICERS: Realizing that your built motor will keep breaking half-shafts forever
HOTRODDERS: Functional air ducts to cool the big-block
RICERS: Six different cosmetic air dams in random locations
HOTRODDERS: Polishing tail-light lenses to bring out the red color
RICERS: Installing clear tail-lights to bait cops
HOTRODDERS: Cruising and burnout contests at car shows
RICERS: Disco-dancing and stereo competitions at car shows
HOTRODDERS: Old-Tech pushrod chevy LS6 pushing 405 HP
RICERS: State-of-the-art, dual overhead cam Honda VTEC pushing 180 HP
HOTRODDERS: Race-class lettering on the rear window
RICERS: Japanese "Honda" lettering on the rear window of a Nissan
HOTRODDERS: Tach mounted on the dash in the drivers line of sight
RICERS: Bobbing-head doll mounted on the dash in the drivers line of sight
HOTRODDERS: Nitrous oxide
RICERS: "Noss"
HOTRODDERS: Installing a 12-point cage after breaking into the 11's
RICERS: Installing a 12-point cage for more places to mount gauges
HOTRODDERS: Feeling the car shake form a lumpy cam
RICERS: Feeling the car shake from booming base
HOTRODDERS: Doing a short burnout to warm the tires before a pass
RICERS: Weaving from side to side cuz nascar racers do it
HOTRODDERS: Comfy stock buckets on a 9-second street car
RICERS: back-breaking fiberglass racing buckets on a 17-second street car
HOTRODDERS: Spending $2000 to get a new Z28 into the 11's
RICERS: Spending $12,000 to get a Civic into the 12's
HOTRODDERS: Showing off a 500 HP dyno sheet
RICERS: Boasting that thier 150 HP mill makes more HP/liter
HOTRODDERS: Installing subframe connectors to stiffen the chassis
RICERS: Connecting the subframes with neon lights
HOTRODDERS: Throttle steer
RICERS: Torque steer
HOTRODDERS: Leaving on the third amber light at the strip
RICERS: Blowing through red lights on the street
HOTRODDERS: Turning a $2000 "fixer upper" into a 10 second car
RICERS: Spending $20k on a car then another $20k on mods only to turn it
:dsm: :talon: :laser:
I see your point here, but I give this thread a couple more posts before one of two things happens, 1)It will become a honda thrashing thread and get closed or 2) a mod will stop that from happening and close it right away.
Yah, this was originaally a "imports versus domestics" list. Did you
add the "hotrodders" ,"ricers" thing or is just from somewhere else.
For example, i don't think there are too many DSM's w/ throttle steer but a whole lot w/ torque steer. :p Nice list though
It was origionally HotroddersVs.Ricers, IU just added in dsm and honda cause it sorta it
And quickly, too.
Y'see, we just don't call things "rice" or "ricer", just like we don't use other once-common terms of blind, prejudicial, bigoted, perjorative and unkind ilk.
Even when they are ricers.
Status
