steve
DSM Wiseman
- 17,248
- 3,910
- Feb 3, 2002
St. Charles,
Illinois
The bleed hole goes on the port the ball doesn't seat against. It's to bleed off the trapped pressure that would otherwise hold the wastegate open after the ball reseals. If your MBC only allows you to hit 13 psi then maybe you need a stronger spring. Check it out of the car and see what pressure the ball seals to before opening. That will be the same pressure your turbo can build before the valve opens and actuates the wastegate.
Steve
Steve
HAH.... I love this site...
