holset hx35 question
RocCitySlayer
792
7
Nov 20, 2011
Rochester, New York
I was wondering if the Holset HX35 Bep .55ar housings are specific to dsms or if those came with the cummings trucks? I think I might have to buy a new one but I might have to try to find one at a junkyard if possible. Help needed please
Bulls eye power makes the BEP .55ar bolt on housings. They did not come factory on anything.
Is this housing the only one that will work on a hx35 for a 95 gsx?
Um... how about the stock one? Get a t3 manifold and use the stock housing, it's a better option IMO. I've ran the bolt-on housing with a stock ported manifold, and I've also used the stock 12cm housing and a cheapo t3 manifold. If you use an open manifold the spool will be a bit slower (than with the dsm bolt-on housing), or using a divided manifold spool could maybe be quicker.
