Holset Hx35 Oil Feed Question
AbsolutGS-T
50
May 10, 2010
Vernon, Connecticut
Hey guys Im going to be running a Hx35 on my 7bolt. I still have my balance shafts in. Do I need a restrictor when Im going to be running from the OFH or will I be fine without it?
Thanks in advance,
Dave
Ok thanks I will do that. Whats the Highest that the holsets can handle for pressure? Also if it is too high of pressure what restrictor do you recommend that I go with?
Thanks
Dave
Search "holset" by title and you will recieve this
DSM Forums - Search Results
Look for the oil thread and you will be here
http://www.dsmtuners.com/forums/turbo-system-tech/244467-holset-hx-35-oiling.html
Travel to post #13
http://www.dsmtuners.com/forums/turbo-system-tech/244467-holset-hx-35-oiling.html#post151402191
Read post #13 to see that
"12. Oil pressure of 150 kPa (20 lbf/in2) must show at the oil inlet within 3 - 4 seconds of engine firing to prevent damage to turbocharger bearing system. A flexible supply pipe is recommended.
13. The minimum oil pressure when the engine is on load must be 210 kPa (30 lbf/in2). Maximum permissible operating pressure is 500 kPa (72 lbf/in2) although 600 kPa (88 lbf/in2) is permitted during cold start up. Under idling conditions pressure should not fall below 70 kPa (10 lbf/in2)."
30psi minimum
72psi maximum
It is also speced by Holset to use a minimum oil drain of 19mm (-12AN is what you want to use)
