Hks Bov
jenkinsfan1
104
Jun 5, 2008
Chicago, Illinois
I have it on my 99 Gs-t its fitted and works great but I keep hearing all these problems happen if you let it "blow off into the air" instead of back into the intake but I have done my research and found you can get the bypass valve will that solve the problem of the ecu reading the part?
HKS USA Standard Bypass Valve
Theres the link to what im talking about.
Instead of plugging the hole you can just recirculate your aftermarket bov into the intake. If you don't want to recirc you can plug the hole, the car might run okay and it might not. Please note that before I decided not to recirc my bov I have a wideband o2 and a logger to make sure my a/f's are right and I'm not running into any problems. I sit at 14.7 idle and 10.9-11.2 at WOT without a MAFT and without recirculating my BOV. As someone stated I think it all depends on the car, some cars are okay without recircing but some just go to hell. I would buy the injen for the stock BOV (with the bov recirc tube) then if you don't want to recirc plug the hole and later on down the line if you decide to recirc again you dont have to buy a whole new intake.
This the kit you need for your HKS bov. eBay Motors: HKS SSQV BOV Recirculation Fitting 1421-FIT001 (item 220243249973 end time Jun-12-08 21:00:42 PDT) Just follow the instructions and run some hose from the bov to the tube on the intake. If you're concerned about sound, I can hear my 1g bov and I still have the nasty rubber intake hose. It will only cost you a little extra and it's worth it to have your car running right. You're gonna have enough problems keeping your DSM running without deliberately messing things up by venting without the proper setup.
Thanks rayek so what your saying is I can just plug up the hole for the stock bov hole on the after market intake and still use the after market bov like im doing right now? then if things get rich i can buy the bypass valve or put the stick bov on?:dsm: love
Yes that is what I'm saying :). Don't make the same mistake I did. I had to buy another intake altogether since the one I got was "with aftermarket BOV". Just get the stock BOV one, then you have the choice to do either. :thumb:
I HAVE ANOTHER QUESTION IF ANYONE WOULD TO ANSWER IT. i JUST BOUGHT THE N1 DOWNPIPE AND EXHAUST BUT WHAT ABOUT THE TEST PIPE OR THE STRAIGHT PIPE OR THE HIGH-FLO CAT? WHICH ONE IS RECOMENDED AND WHAT DO THEY DO AND DO DIFFERNTLY I AM NEW TO EXHAUST SYSTEM AND WANT TO KNOW ABOUT HOW THEY WORK AND NO I HAVNT PUT THE DOWNPIPE OR THE EXHAUST ON YET
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
