Ceddy
- 847
- 42
- May 10, 2006
Reading,
Pennsylvania
I just picked up a machined 7cm turbine housing off of ebay for cheap.
Its in very good shape, no cracks at all. But I have no idea what it was bolted on to.
I know a lot of the vendors used the machined mitsu housings back in the day, before cast bolt-on housings became popular. But after searching I can very little info on them.
The exit of housing, where the exducer would fit in measures 2.295".
Minus 2.228" for a T31 76 trim "Stage 3" turbine wheel, gives 0.033" clearance around the wheel.
Is this close to the correct amount of clearance?
The other side of the housing where the heat shield would fit in behind the turbine wheel measures 2.907". And the inside of the "V-band" clamp where the CHRA fits measures 3.168".
Anyone know what CHRA would fit this? Are all of the T31 CHRAs one standard size?
Also does anyone remember what some of the old turbos with the machined housings were named? It would help me a lot in searching.
Or does anyone recognize the v-band clamp?
Thanks.
!!! That looks like a Turbine housing off an OLD Extreme Turbo MUTT!! That housing was machined to accept a Garrett T3 style center section. The clamp in the picture is what REALLY gives that away.
