help with megasquirt ignition
The diagram is mostly correct, though it's more common to use a 1k5 resistor for R12 rather than a 470R resistor.
You're going to want to do something like this for spark control:
MS2-Extra Ignition Hardware Manual
MS-I is on its way out, as is MegaTune. MS-II and TunerStudioMS are the new de facto standards. The v3.0 board is still the only way to go.
What else do you want to know?
If it's your first time building a Megasquirt ECU it might be easier to follow the directions in the MegaManual and then make any necessary modifications. As you can see, they're not difficult, so it won't add much more time.
The standard stim can't create the 420A crank signal, only a JimStim can.
The Bosch BIP373 is the standard ignitor. VB921's are prone to overheating and catastrophically failing; they're also hard to find.
I wish I would have know that in advance. just finish putting together a 2.21 stim. is their a ### to test a stim to see if i build it correct? last does my soldering look ok to u?
Well, you can still use it to test the ECU. You can test whether or not the ECU powers up, and the CLT, MAT, O2, and TPS sensor inputs.
You want a stim for your stim? :)
It's not a complicated board, so you probably assembled it correctly. Just go over the instructions and double check the things like diodes/LED's, IC's, and transistors; all the things that need to go in a certain way.
It's hard to tell in the first picture. The third picture looks okay, but I'd probably use more solder on the DB37 pins.
