DGajre777
DSM Wiseman
- 4,772
- 133
- Jul 16, 2004
Orlando,
Florida
RedTurboEclipse said:i have a mtx class d mono amp
and a 12" kicker 4 ohm sub
i dont have the official numbers but the mtx amp is rated at putting out ~300 with a 2ohm load.. and ~200 with 4ohm.. the sub max watt is 300.. theres no way to get the most power from the amp/sub unless i get a new sub at 2 ohms correct? i hear these things about bridging but ive read with mono class d amps its bridged internally so this doesnt apply..
You can add another 4 ohm sub to your 12" OR get a new 4 ohm Dual voice coil sub. You don't have to worry about briding a mono amp, it will detect the load and provide more power if you set it up in 2 ohms.
You have them hooked up in parallel now, you need to hook them up in series (like I said earlier) to get 125 watts instead of 100. IF your amp is a mono amp, it will only have 1 channel on it, not 2 so I don't know how you have speakers wired on 2 channels anyway.
sorry
